Re: Super A not running well
Posted by LarryT on January 10, 2011 at 14:59:19 from (68.35.57.27):
In Reply to: Re: Super A not running well posted by gene bender on January 10, 2011 at 04:01:34:
What altitude are you at Gene? I am thinking at this high altitude it may make a difference because I am not the only one with these older tractors with the problem If it was only me then I would say that there would be a reasonable fix. I have rebuilt and even had the carburetor flow checked and it didn't change a thing. I change plugs every fall and it gets a timing and points check at least twice a year. Since the engine was rebuilt 2 years ago the compression is over 130 dry so I don't see a valve problem or internal problem with the engine. So, If you have something constructive to help or steer me towards another reason for it behaving in this manner, please let me know. Thanks, LarryT
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
