Keith - If it charges +20 amps with the "F" terminal grounded, the belt is plenty tight (ie. not slipping).
Now if the battery is fully charged, ammeter bouncing between +3 and +10 is not unusual - it's just the ammeter responding to the rapid cycling of the voltage regulating element (relay) inside the voltage regulator.
Now if the battery is less than fully charged (ie immediately after startup) the ammeter should show steady +15 to +20 amps at full throttle. It should continue charging like this until the battery reaches full charge where it will taper back to your +3 to +10 "bouncing".
However the ammeter bounces +3 to +10 with the battery less than fully charged, the problem a failing voltage regulator.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
