Re: 560 Power steering line
Posted by tn terry t on January 10, 2011 at 19:42:58 from (205.188.116.19):
In Reply to: 560 Power steering line posted by bc on January 10, 2011 at 17:35:53:
you can go to the autoparts and get i think 3/8(its been a while)brake line 3/8 pipe tap and a 3/8 flare to 3/8 pipe brass elbow unbolt that block cut the line off and drill and tap the block for the 3/8 brass elbow on the other end i just used a 3/8 compression fitting a few inches from where it goes back in the steering block out front with a tubing bender you can follow the original line path almost looks factory and one he!! of a lot cheeper i did this seven or eight yrs ago to my father-in-laws 560 i will be doing mine before too long
