Re: farmall 560 starter
Posted by Owen Aaland on January 10, 2011 at 19:57:08 from (65.161.86.69):
In Reply to: farmall 560 starter posted by monkey wrench on January 10, 2011 at 18:00:28:
The diesel starters are quite a bit larger and more powerful.
You can also use the 30MT series off a 706 or 35MT from an 806 .f you really need the cranking power. You will need to use the right drive depending on your flywheel and ring gear.
