Just to be clear, the differential is in the same case as the tranny and is filled through the plug in the tranny cover, to the level of the check plug described near the left brake rod.
The final drives (stictly a gear reduction arrangement, not a differential) are indeed separate from that. Fill/check plug is at the forward end, above the pan, on the inboard side of each. What I've found with them is that the recommended volume of gear oil is les than what it would take to rise to the level of the fill hole bu that, once installed, there's no way to check the actual level without filling her up. As long as the pan gasket's good, no harm/no foul.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
