Re: 444 IHC wont get out of reverse?
Posted by Janicholson on January 10, 2011 at 22:16:26 from (67.72.98.45):
In Reply to: 444 IHC wont get out of reverse? posted by TDS - Swartz on January 10, 2011 at 21:49:46:
The shifter lever tip in the trans is worn and has dropped out of the gear it was shifting.
Remove the lever from the trans top, and realign the gear shift rails to a common neutral. Pushing the clutch will help. Then reinstall the lever.
Welding up the worn edges of the tip, and grinding to make it tighter in the slots without binding is best. Jim
