Re: In Need Of Part
Posted by glennster on January 11, 2011 at 06:20:27 from (76.223.251.130):
In Reply to: In Need Of Part posted by ol-shep on January 11, 2011 at 05:20:46:
if you cant find an original style pulley, shoups has weld on hub pulleys. you can get the 1 3/8 x 6 spline hub for 10.69, part number x13806p, for the x series hub and if you knew the pulley diameter and belt size, the pulleys run 20 to 40 dollars. a 10 inch pulley will cost 29.15, part number p100x. shoup parts dot com, enter the part numbers and have a look see.
