Re: Farmall a governer
Posted by redblood on January 11, 2011 at 06:24:20 from (75.219.124.116):
In Reply to: Farmall a governer posted by redblood on December 29, 2010 at 07:50:31:
Thank U, Your idea about the shim, worked perfectly!! Last night I measured 750 rpm, now to slow her down a bit.......
I did check my meter against another, same results.
Once again, thank you for sharing your knowledge with me.
Joe
