Re: In Need Of Part
Posted by gene bender on January 11, 2011 at 09:51:05 from (67.55.227.196):
In Reply to: In Need Of Part posted by ol-shep on January 11, 2011 at 05:20:46:
You cant get a big enough on on the PTO to run the blades fast enough. It needs to be around 16-18 in dia and there isnt enough room to mount one that big then how would you run the belt. You run those mowers off the belt pulley On a C,SC,H or something like that you can run a mower off the PTO as theres room to run the belts and have slearence for the pulley but not on an A,SA ect.
