The whole story of which parts will mix and match is complicated. From your picture, it appears that you already have a later PTO on your tractor. Check the part number on your main PTO drive housing. You should find it cast into the part. The early one is 6615D, the later 9091DC. If you have the later part number, a belt pulley attachment from a later A, Super A etc. will fit onto your PTO. If you have the early part number, a belt pulley from an early A is required.
If you find an entire PTO and belt pulley attachment that is the opposite of what you have, you can install the whole thing by using some of your existing unit. The one thing you can't do is cross a belt pulley attachment onto the wrong version of a PTO. That is why you need to be sure which PTO you have.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
