Re: In Need Of Part
Posted by Lmack on January 11, 2011 at 17:11:47 from (98.66.223.39):
In Reply to: In Need Of Part posted by ol-shep on January 11, 2011 at 05:20:46:
You need to consider purchasing and mounting the 90 degree box (see Gene's comments). The belt pully is much faster and and that speed will be needed to drive belly mowers designed for mid mount on Farmall
A, SA, etc.
