Posted by Yooper Farmall on January 12, 2011 at 07:34:29 from (141.210.112.16):
Thanks to all the great advice here, I finally got My H converted to 12 volts. I used a Hitachi alternator and have about 1/2" of clearance under the hood (The delco simply wouldn't fit). I had already purchased a converstion mounting bracket so just used that, although I could have just drilled out the original. The diode is soldered to the red wire coming off the resistor mounted to the coil. The diode is triple shrink wrapped for rigidity as Bob suggested. The fusable link is the thick green wire. My parts store didn't rate the links by amps, so it was suggested to me that 14guage was the approporiate site fusable link.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
