Re: Farmall A lift conversion please help
Posted by LarryB in Va on July 09, 2000 at 13:58:17 from (63.95.120.222):
In Reply to: Farmall A lift conversion please help posted by John on July 03, 2000 at 17:05:42:
I converted one this week. Used a wood splitter pump and valve and a little 3 inch throw cylinder. I first changed to an alternator, made a bracket to set the alternator about 4 inches lower than where the generator was, made a bracket for the pump and put it just above the alternator with the supply line up and the pressure line down. Used a 3" belt pulley. Made a bracket out of 3/4" steel and mounted the cylinder bracket to the two holes on the left clutch housing. I used the existing holes in the hand lift mechanism for the cultivators and pinned the other side of the cylinder. Made a hyd. reservoir out of 2x4" tubing, welding in pipe fitings for supply, return & fill. Drilled two holes at 90 degree angles in the fill plug, which was a 1/2 " pipe plug, for ventilation. Moved the battery box under the seat and placed the reservoir where it was. I mounted the valve on the reservour, used 2 30" hyro hoses for the cylinder. a 48 " pressure hose from the pump to the valve, and one inch clear plastic tubing for the returns to the reservoir. Worked like a charm. It uses all the original hand lift mechanisms. The only thing worrying me is the increased load on the fan bushing from those tight belts, but they are cheap. If you can weld and cut steel, it is easy done. Hope this helps.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
