Re: Farmall H lights and light switch
Posted by gene bender on January 12, 2011 at 11:48:47 from (67.55.227.196):
In Reply to: Farmall H lights and light switch posted by Yooper Farmall on January 12, 2011 at 07:40:05:
You are correct the gens out-put could also be changed by moving the third brush to sui9t your needs with the cut-out. When running a mag there was no battery drain when the motor was running so you only needed a battery when starting. With things in shapr the motor would start easy thus not needing a verry hi rate of charge.
