Re: wd 9 pulley
Posted by glennster on January 12, 2011 at 12:05:14 from (76.223.251.130):
In Reply to: wd 9 pulley posted by greyfoxxca on January 12, 2011 at 10:12:34:
build a couple wooden ramps, 2-3 ft long, 8 to 10 inches high. set the back wheels up on the ramps and put the trans in 4th gear. fill the cylinders with your favorite concoction, trans fluid, pd blaster, kroil ect and let er set. if and when it breaks free it will roll down off the ramp. you can also put the starting crank in it and hang some wheel weights off the crank too.
