706 hydraulic reservoirs
Posted by Lee Wilson on January 12, 2011 at 14:20:21 from (69.97.85.79):
I drained the oil from the two plugs on the bottom of the rear end,and it was clean oil. I drained the hyd reservoir, and it was white as milk. I then ran diesel through the system with a new filter, and drained again. NO diesel came out of the rear drains. I was of the understanding that this tractor used the same oil for the steering, transmision and rear end. I have an IT manual coming, but havent got it yet. If its a different oil, where is the fill for it? Thanks in advance for sharing your knowledge.
