Re: 784 TA Issues
Posted by Jimb2 on January 12, 2011 at 17:10:31 from (99.240.236.11):
In Reply to: 784 TA Issues posted by RHeimiller on January 11, 2011 at 21:37:55:
Hi, the 74/84/95/32XX Series were all built in Doncaster UK and Diesel engines build in Neuss Germany. The units sold in USA were shipped in parts and assembled in USA using some different parts than UK built ones. One big differences was USA had Delco electrical system and UK had Lucas electrics. In Canada the tractors were fully assembled but with Canadian safety requirements. The tractors could be ordered with either T/A or Fast Reverse as an option.
Direct drive (HI) is a hydraulic clutch pack and in LO is a mechanical sprag clutch with a friction clutch prevents free wheeling. There is a small hydraulic pump that runs off the PTO shaft and is fed by the hydraulic oil cooler return line, that is used to power the hydraulic clutch pack for the direct drive (HI). There is a pressure check and adjustment on the output of this hydraulic pump.
email at clarabrownlee@rogers.com if you wan to know more.
JimB
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
