Re: The WORST IH tractor ever built!!!
Posted by gbs on January 12, 2011 at 17:31:29 from (66.83.123.242):
In Reply to: The WORST IH tractor ever built!!! posted by johnTUR on January 11, 2011 at 16:07:28:
all makes have short comings of on thing or another some were just ahead of there time others behind times, daddy bought a slightly used m right after WW2 because you couldn"t buy a new one at the time,it was put to had hard work,pulled a silage chopper, combine, 5 disc tiller ,chisel plow, subsoiler,gang discs of which 0ne was a 20 blade offset even done some of the planting ,cultivating and loader work. it was always well serviced and maintained,he was replacing a worn out steering wheel one day and told us that was the 5th one, also had worn out 3 seats, he said that his brother and him would run it 24 hours a day at times fall plowing and fixing land in the spring he told of one time they ran it none stop for 5 day"s, only reason they shut it off then they got scared of pouring high test gas in the tank while it was running he"s passed on but the old tractor is still there bring used some,he also used other brands but stuck with the m, he also was raised behind a mule
