Re: H Cyl. Head Studs?
Posted by Nebraska Kirk on January 12, 2011 at 22:52:39 from (207.91.4.161):
In Reply to: H Cyl. Head Studs? posted by Gene Norman on January 12, 2011 at 19:18:41:
You can easily make the studs. Just get a grade 8 fine thread bolt as long as the stud needs to be, cut off the head and coarse thread the end. Note: set your die to cut shallower threads than normal, the stud threads need a tight interference fit with the engine block.
