Re: IH 300 Utility Hydraulic Pump Part
Posted by IndyPung on January 13, 2011 at 03:48:20 from (69.174.58.36):
In Reply to: Re: IH 300 Utility Hydraulic Pump Part posted by pete 23 on January 12, 2011 at 17:26:36:
I looked at the pump and there is no hole drilled between my bearing plates that I could see. I don't believe there was any part like this in my original pump. Are you sure that part number is for a plug like that? If so, it looks like I don't need that piece for my rebuild.
Thanks.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
