Re: fast hitch vs three point
Posted by low budget on January 14, 2011 at 02:51:48 from (74.47.176.70):
In Reply to: Re: fast hitch vs three point posted by DanR on January 13, 2011 at 06:31:27:
Deere had power lift with a rockshaft as early as 1928. It was limited in use mostly to mounted implements like cultivators. Fergusons 3 point hitch was a vast improvement and his partnership with Henry Ford in 1939 made it popular. Fergusons true genius was his system of draft control. Case also had Eagle Hitch to make for easier hitching of mounted implements. Advertizing departments will call an improvement an innovation and the competition will say it was stolen.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
