Re: Serial numbers Super C
Posted by farmallhal on January 14, 2011 at 05:42:17 from (76.2.177.91):
In Reply to: Serial numbers Super C posted by Joe P. on January 14, 2011 at 03:02:22:
What do you mean by different hydraulic systems? Can you post photos? Are you possibility talking about one having the 2 pt. fast hitch and one not? If that is the difference the fast hitch was an option that was introduced in 1953 as an option. A lot of Super C's in that time frame and later had that style of hitch. They could also be retrofitted back onto the earlier SC's. Along with the fast hitch on the rear of the tractor there was a remote auxillary hydraulic valve which mounted on the right side of the touch control hydraulic unit with a lever on the light bar to work the hitch up and down. That serial no. tag on the seat base is the only place you will find the unit chassis s/n. The motor s/n will not be the same as the chassis. Hope there might be something to help your understanding here, Hal.
