Posted by Farmall Bob on January 14, 2011 at 09:46:28 from (76.179.113.97):
In Reply to: Transmission Question posted by Tom in Iowa City on January 14, 2011 at 06:37:29:
Hi Tom.
In reference to your question. What you are looking for is a good set of beveled gears, and to obtain that the manufacturer uses a master gear and a new cut gear and inspected on a rolling gear tester. The master gear would be red leaded and the new cut gear would be blued. This should give a good wear pattern for Involute, Tooth spacing, the Lead and composite errors. If not then the operator has to make adjustments to his gear cutting machine. When a gear is assembled into the casting and meshes with another it may be indicated for proper fit like .012-.015. Thses gears wear together and if one of them breaks down and needs replacing the proper way is to replace both. If not you may receive noise, uneven wear, excessive wear, etc. I am not saying it will not work and if it were me I probably would change just the bad gear and use Red Lead and Blueing to get as proper fit as possible. Hope this helps.
Today's Featured Article - Fire in the Field A hay fire is no laughing matter-well, maybe one was! And a good life-lesson, too. Following World War II many farm boys returned home both older and wiser. One such man was my employer the summer I was sixteen. He was a farmer by birth and a farmer by choice, and like many returning soldiers, he was our silent hero: without medals or decorations, but with a certain ability to survive. It was on his farm that I learned to use the combination hand clutch and brake on a John D
... [Read Article]
Latest Ad:
[More Ads]
