Re: Transmission Question
Posted by gab on January 14, 2011 at 19:14:47 from (70.104.107.73):
In Reply to: Transmission Question posted by Tom in Iowa City on January 14, 2011 at 06:37:29:
I'd get those gears cleaned up before you take it apart, check the pattern with some bluing, record the backlash and then keep the shims in order when removed, probably three stacks of shims. Then you can put it back together and you got somewhere to start, move a shim here and there to get closer.
Maybe you can google how to set up a differential and get a better idea.
