Re: engine oil
Posted by holmesw on January 15, 2011 at 05:31:55 from (70.41.32.59):
In Reply to: engine oil posted by Mike from Wisconsin on January 14, 2011 at 16:52:55:
Ideally you would use what has been used over the past few years. If history is unknown I would use nondetergent. The chances are too high, that when you dump in detergent, that it will loosen up the sludge that has accumulated for the past however many years, and could cause engine damage. Unless you know what has been run in it, or unless it has had a rebuild and has been cleaned up to perfection, I would use nondetergent.
