Posted by Janicholson on January 15, 2011 at 07:39:02 from (67.72.98.45):
In Reply to: ta 560 pulling posted by monkey wrench on January 15, 2011 at 06:30:26:
You may want to repair it. (I know that is not what you asked) they are fine parts of the tractor. If pulling only in classes that do not allow TA use, the easiest method would be to put a new disk in the TA and not reconnect the external linkage. If you are putting twice the power through the TA, a TA eliminator kit is best. If you weld the internal components you will have slag and beads of metal floating around in the trans, and no assurance that it will hold the power. It could be disassembled to get to the planetary gear set, and welded on the bench with professional level welding practices, cleaned and reassembled. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
