Posted by Janicholson on January 15, 2011 at 07:53:05 from (67.72.98.45):
In Reply to: engine oil posted by Mike from Wisconsin on January 14, 2011 at 16:52:55:
Drain the oil and put a bent stiff (#9) wire into the drain hole. scrape it around and across the pan bottom. Pull it out and pour a quart of Diesel or Kero into the oil filler (plug out into a fresh pan) If solids and crispy flakes come out I would pull the pan and VC to clean the engine internally, then with fresh 15-40 oil and a new filter I would go on with life. If it cane out with just a little soft deposits I would use 15-40 right away and go on with life. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
