Re: Farmall Super H brakes
Posted by Janicholson on January 15, 2011 at 13:17:00 from (67.72.98.45):
In Reply to: Farmall Super H brakes posted by D Ervin on January 15, 2011 at 10:30:04:
The measurement from the mating surface of the housing casting (where it attaches to the tractor) to friction surface down in its depths is important.
The stack of the inner disk, the outer disk, and the expander (when placed all together with the expander fully collapsed) is also measured. The purpose is to measure the total difference between the tractor friction surface and the housing friction surface then subtract the thickness of the stack. The amount of clearance should be about .050". If it is dramatically more than this the linkages will need to pull so far that they loose effective angle. The gap increases when the tractor surface the expander surface, and the housing surface wear during use.
To reduce excessive clearance, the housing is machined to make this wear disappear, returning it to near new condition. Readjustment of the pull rods will be needed. Jim
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
