Re: Farmall M engine size
Posted by D Slater on January 15, 2011 at 14:42:53 from (184.15.8.48):
In Reply to: Farmall M engine size posted by mainamana on January 15, 2011 at 11:13:01:
Above the oil filter and on the side of the engine block look for the cast number and letters following the number. Should be 6722D?, second letter changed over the years. Most times IH replacement blocks used another casting #. IH did make some replacement blocks with C248 cast on them. Engine serial # stamped on the block down below the # one spark plug, should have the prefix letters FBKM on non diesel engines. Replacement blocks don't have a serial # on them unless someone stamped one when installing.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
