Re: Cub Low-Boy Discharging
Posted by Phil Auten (TX) on July 10, 2000 at 05:54:22 from (206.175.72.226):
In Reply to: Cub Low-Boy Discharging posted by Ed on July 08, 2000 at 16:27:00:
Ed,
Sounds like you have a couple of bad cutouts/voltage regulators. Either the contacts are stuck and or aren't making good connection when running. The stuck contacts will discharge the battery back through the generator when off and bad contacts will cause the generator to not charge while running. Check the contacts, file with a point file if required and let us know what you find.
Phil
Post A Followup
: Re: Re: Cub Low-Boy Discharging
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
