Re: Farmall Super H brakes
Posted by pete 23 on January 15, 2011 at 16:15:40 from (173.87.15.134):
In Reply to: Farmall Super H brakes posted by D Ervin on January 15, 2011 at 10:30:04:
Good advice on all counts. Be doubly sure to polish those machined surfaces around the outer diameter of the actuators and inside the drums. I always use a light coat of lube on those and on the ball grooves also but that is my way. That actuator has to spread out to brake so it needs to move free outward over those surfaces, and don't overlook the splines on shaft as well.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
