Re: Farmall H - 5th gear only???
Posted by farmall green on January 15, 2011 at 17:57:34 from (166.204.130.3):
In Reply to: Farmall H - 5th gear only??? posted by Matt Weltz on January 15, 2011 at 17:15:50:
Is it stuck in 5th gear? if so bottom of shifter rod may be wore off and slipping out of shifter rail. you can pull shifter out and see if it forward. 4th and 5th is on the left in side transmission.. if this is problem i have welded up the bottom of shifter and ground it back to spec on a couple before... hopes this helps
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
