Re: Farmall H - 5th gear only???
Posted by Haas on January 15, 2011 at 18:38:54 from (75.216.222.47):
In Reply to: Farmall H - 5th gear only??? posted by Matt Weltz on January 15, 2011 at 17:15:50:
Farmall Green has a good point. It could also be a problem with the shifter rails. You can determine that by pulling the shift lever out. There is a pin that holds the lever in. Once it's out, you can see the shifter rails and move them to see if you can get it in another gear besides 5th. Also, you can try putting the PTO in gear. Then try to turn the PTO by hand with the tractor engine not running. If you can turn the PTO while it's in gear, then there is a problem with the constant mesh gears at the front of the tranny.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
