Re: Starting a Cub in the cold
Posted by El Toro on January 15, 2011 at 18:56:15 from (108.3.200.96):
In Reply to: Starting a Cub in the cold posted by ellson on January 15, 2011 at 18:36:45:
You should pull a plug wire and see what the fire looks like when it won't start. Your coil may be getting weak in your mag causing the no start. I would try a hair dryer to heat the mag if you're close to house power. Then see if that helps with the starting. Hal
