Your email isn't active so I will just post the guys phone number. (two six two) 818-2795
If you have a carb, manifold, mag/coil, and radiator for a gasser I would take them off your hands and we could both have a W-9. He said he found this one super cheap and bought it for those parts and is just going to part out the rest...it's a shame. He said it has good tin so that should be a help. It is just outside Kenosha.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
