Re: growling 806
Posted by DeltaRed on January 15, 2011 at 19:51:36 from (97.124.209.33):
In Reply to: growling 806 posted by RustyR on January 15, 2011 at 14:53:11:
Is this sound old,or is it a new arrival?If its old ,run it and dont worry.If newthere's not much you can do,so run it till it craters,then install a new TA.For giggles,run a series of pressure checks at the multiple control valve.
