Re: 400 coolant in oil
Posted by Nebraska Kirk on January 15, 2011 at 20:28:07 from (207.91.4.161):
In Reply to: 400 coolant in oil posted by obH on January 15, 2011 at 16:59:07:
I have worked on several 400s and if I were you, the first thing I would do is take the head off. If the head gasket is blown it will be easy to spot once the head is removed.
