Re: 400 coolant in oil
Posted by rustred on January 15, 2011 at 20:29:49 from (74.200.18.155):
In Reply to: 400 coolant in oil posted by Denis in MI on January 15, 2011 at 16:59:07:
well the best place to start looking is where you are finding the coolant, in the oil pan. that requires removing pan and watching for leaks coming from around cyls. did you have this tractor running? if not then things may be rusted up and you wont find a leak. head gskt. possible also.good idea to pressurize the cooling system. if unit is in running order can check for bubbles in rad also.
