Re: Super A 3 point mower or belly mower?
Posted by dan mcdonald on January 16, 2011 at 05:50:38 from (12.192.13.26):
In Reply to: Super A 3 point mower or belly mower? posted by johnny anderson on January 16, 2011 at 03:54:33:
I cut 6 acres with an H that has a woods belly mower under it cuts real nice. I use a small (36") zero turn to trim after cutting with the H.
