Re: Farmall H - 5th gear only???
Posted by mkirsch on January 16, 2011 at 07:26:47 from (67.253.216.24):
In Reply to: Farmall H - 5th gear only??? posted by Matt Weltz on January 15, 2011 at 17:15:50:
Ask the guy what happens if he shifts it into any other gear.
If it stalls, it's stuck in 5th and it's an easy fix. Described above.
The real question at that point is, how to deal with the guy. You can tell him how to fix it, but then he may decide the tractor is now worth a lot more because it doesn't have major transmission problems...
Is he pricing the tractor as if it has major transmission problems?
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
