Re: 706 manual
Posted by Doug - Iowa on January 16, 2011 at 14:21:50 from (208.126.7.248):
In Reply to: 706 manual posted by crystal allis on January 16, 2011 at 10:17:45:
I have several and they are all about equal for the info I have needed, including the I-T manuals. If you are planning a joystick you"ll need a power beyond block. Search this site under Farmall and "power beyond" and you"ll find several threads discussing it over the years. Your hydraulic valve body is under the seat. Your"s might be the one that has a cast endplate which means you might have to find a body that has a seperate end plate. The book should show it. If you serial number has a "Y" it is the 12 gpm hyd pump which would be desireable.
