Posted by ihredo4 on January 16, 2011 at 14:56:01 from (216.73.228.119):
In Reply to: H engine to w4 posted by Michael Priar on January 16, 2011 at 11:15:02:
You will have to change both the front cover and the rear plate. The front cover has a one or two piece bracket that mounts around the crank shaft and then mounts to the cast tub. This is your front engine mount. The plate on the back has two arms that stick out around the flywheel. This is bolted and pinned to the rear of the cast tub. There are some shims that go in under the front mount to get the engine into alignment. I have yet to figure out how you determine how many shims go in though.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
