Re: Warped Rear Main Seal Retainer
Posted by farmhand on January 16, 2011 at 19:00:23 from (173.218.134.86):
In Reply to: Warped Rear Main Seal Retainer posted by sflem849 on January 16, 2011 at 17:33:40:
If you will find a 400 or a 450 rear main retainer they are cast iron and have a different gasket set up than the MD. I have changed my MD and SMD over to them after running into the same thing you are looking at warped retainer not holding the rear seal and leaking. I even tried to get another retainer thinking I could find a better one before I found out about the different set up in the newer diesels and it was in worse shape than the one I had and thats when I learned about the later diesels set up.
