Re: farmall h regulator wiring
Posted by John T on January 16, 2011 at 19:14:55 from (66.87.7.205):
In Reply to: farmall h regulator wiring posted by farmall66 on January 16, 2011 at 18:07:10:
The charging system can be the same regardless if its a Mag or a battery powered coil distributor ignition.
Originally the earlier systems that had a combination 4 position LHBD (L= low charge H=high charge) light switch and charge control used the simple Cutout Relay while the later 3 position Off Bright Dim light switch only systems used a full fledged Voltage Regulator. A tractor could be be converetd from cutout and LHBD light switch charge control to a full fledged voltage regulator but you may as well keep her original to match what switch you now have.
Bob M has all the wiring diagrams available I dont have the URL link handy
John T
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
