Re: Farmall 400 Quit
Posted by Shawn in PA on January 16, 2011 at 20:51:14 from (24.154.38.87):
In Reply to: Farmall 400 Quit posted by mhogan on January 16, 2011 at 15:48:04:
Do as Jim said, dry everything out, and visually inspect for spark at the coil before you start tearing anything apart. And while you"re there, since it is converted to 12 volts, make sure you have either a 12 volt "internally ballasted" coil, or a 6 volt coil with an external ballast resistor. If the coil has "use with external resistor" or something similar written on it, ensure that there is indeed a resistor wired before the coil. Shawn
