Re: Super A 3 point mower or belly mower?
Posted by mkirsch on January 17, 2011 at 06:05:00 from (64.80.108.57):
In Reply to: Super A 3 point mower or belly mower? posted by johnny anderson on January 16, 2011 at 03:54:33:
I vote for a belly mower. You get a better "finish" than with rear mower.
One limitation of a Super A with mower is lack of live PTO.
Every time you press the clutch, the mower is going to stop, but only after carrying you 10-20 feet as the blade momentum drives the transmission through the PTO shaft.
You need to be VERY careful mowing up to objects. Press the clutch well ahead of time, and make sure you have an "out" if the mower doesn't wind down in time.
I mowed with a Cub for four years, and finally got sick of trying to maneuver it around trees and other obstacles. Last spring I bought a Husqvarna conventional lawn tractor with 22HP engine, 46" deck, and hydrostatic transmission. It moves faster, turns shorter, and cuts better. Plus I cruise under the low branches, instead of eating them for lunch.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
