Re: farmall h regulator wiring
Posted by farmall66 on January 17, 2011 at 06:36:25 from (134.24.149.32):
In Reply to: farmall h regulator wiring posted by farmall66 on January 16, 2011 at 18:07:10:
THANKS FOR ALL THE HELP
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
