Re: Farmall 400 Quit
Posted by Bob M on January 17, 2011 at 07:19:57 from (67.240.171.41):
In Reply to: Farmall 400 Quit posted by mhogan on January 16, 2011 at 15:48:04:
As Shawn suggests, if your 400 has an ignition ballast resistor, the problem could the resistor has failed. It's not uncommon when blowing snow gets onto the hot resistor. It'll cause it to crack and instantly shut down the engine.
Quick check: Temporarily bypass the resistor by jumpering the terminals. If you now have spark at the plug, get a new resistor (about $8 at AutoZone, etc).
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
