Re: Farmall 400 Quit
Posted by El Toro on January 17, 2011 at 09:58:23 from (108.3.200.96):
In Reply to: Farmall 400 Quit posted by mhogan on January 16, 2011 at 15:48:04:
Pull off a plug wire and have someone make an attempt to start the engine while you hold the plug wire about 1/4" away from the plug. See if there's any fire to your plug. If there isn't run a separate wire from your battery to your coil then see if it will start. If you don't have a ballast resistor and it starts you're probably not getting battery voltage to your coil. Use a volt meter or test lite and with the points open and your ignition switch in the run position see if there's voltage at your coil. If there's no voltage here check your ignition switch for voltage and the wire that feeds battery voltage to your ignition switch. Hal
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
