Super A with frozen engine
Posted by Ralph Kramden on July 10, 2000 at 10:23:33 from (209.239.194.14):
Welllll, it seems that even in Northern California, in the town of Sebastopol, it does get cold enough to crack a block. The frozen engine would, I found out after I removed the radiator and pulleys, turn backwards half a rotation. So, off with it's head! The number 2 and 3 cyl's. had serious rust in them, so as to prevent rotation. I cleaned them up, honed a little, oiled and etc., and she rotates fine now.
There are, however, cracks in the top of the block that run between the coolant holes and the cylinders, or the sleeves. My machinist looked at it and then used a term that can't be repeated here. BUT he IS going to see an old friend in the Bay Area this week, a old guy who can weld anything, so there may be hope for the old block yet, by welding it and then having my friend re-surface the block. Then I suppose it would be foolish not to totally rebuild the engine and head, so that's my plan.
Interestingly, I was visiting a web page maintained by Brian (link below) and he has pictures of WHITE Farmalls used as demonstrators way back when. My loader is white, under the red , peeling paint.I can tell it's the original color. Does anyone know of white impliments?
Just in case, I am searching now for the casting numbers on the block to send to a wrecking yard in case I need a replacement block.
Post A Followup
: Re: Super A with frozen engine
